How to hook up rd controller
toddgray519
I need some help wiring up a rd controller for the wet sound speakers on my 2023 Yamaha 222xe. I ran the rgb wires in and out out each speaker around the boat do I just connect the 1 end and cap off the other end or do I connect both ends of the wire to the controller The other end running from the 1 speaker in the series in the rgb still on the roll
I’m good on the power wires which I’m going to tap off of the aux switch at the helm
I am a little confused by your wording.
Your RGB wires go into the RGB+ side, you don't need to use both connectors but you can if you want. This controller highly benefits from 3.5mm connection instead of the mic.
No thanks you cleared it up much appreciated
