How to remove the Captain's chair correctly 2015 24(x)
OperationROL
Staff member
Administrator
Knoxville, TN
So every time I need to remove the captain's chair or the co-pilots chair, it takes me 10 minutes to stumble upon a way to do so. Last weekend, I was able to remove one but not the other. What is the correct way to remove the seat?
Bueller?
I would like to know as well. I will be taking delivery on May 4th and have a few mods planned that will require removing the captains chairs from the pedestals.
I wonder how different it is from the 190. For mine I turn the lever as if to swivel the seat, then just pull up on the whole seat. Not sure if this helps
I wonder how different it is from the 190. For mine I turn the lever as if to swivel the seat, then just pull up on the whole seat. Not sure if this helps you but it's better than the other advice you've gotten
I will try that this afternoon.
