Cliff Sadler
I have an AR190 that we rescued from a total loss during Irma in 2017. It is now a full time salt water boat on the West Coast of Florida, stored on a lift, but in the water for up to a week at a time. Covered, but when sitting in the water it generally isn't, and in the summer that means deluge of rain water every day at 2 pm.
I won't go into the discussion of the questionable bilge pump design, I know it first hand.
Here's the question. The factory Automatic bilge pump sits in a cavity 2-3" below the engine room liner. The drain plugs at the back of the boat sit much lower than that. I have looked around at the rear bulkhead of the engine compartment where the drive assembly exits the engine room and into the bilge cavity around the clean out tube and exhaust system are. Is there a direct opening from the cavity beneath the engine room to the aft bilge area, or does it actually flow forward and somehow make its way to the cavity under the ski locker, which may or may not make it to the lower bilge at the transom?
I put the boat on the lift, removed the plugs at the rear of the boat, and 2 days later, there is still standing water in the cavity below the engine room liner where the bilge pump is. I am not sure there is a single point of water collection on this boat. It seems more like there is one area under the engine that is managed by the bilge pump, and another that is managed by the removal of the transom plugs.
Does anyone have an honest to God drawing of the hull and liner for this line of boats? If I can't find one, I'm going to start putting dye colored water into the various places that we always find too much water after a rain, or run, and document it.
This is the closest thing I could find for an exploded drawing, but it is woefully inadequate for this analysis.
