Humming through speakers
Jim Robeson
Springfield, Missouri
Noticed the other day that when the cockpit fridge cycled on that I had a "humming" sound through the cabin speakers but not the speakers outside the cabin. That sound system is on a separate amp than the one in the cabin. I also tried a different switch on my 12 volt panel and it also caused the humming sound to come through the speakers. Does this sound more like a grounding thing and is there any easier way to discover what isn't grounded correctly??
Thanks!!
Jim
I have noticed a similar issue on my boat. I tried various noise isolators without success. The hum was being introduced through the audio source which at one time was a Bluetooth receiver then later a Raspberry Pi. My eventual solution was to use a Toslink optical audio cable to connect the source to the head unit https://jetboaters.net/threads/looking-for-a-12-volt-noise-supressor.2819/
I suspect that your issue is related to differing quality power supplies in the two amplifiers or differing amplification levels.
Thanks @Bruce .... someone else had recommended a ground loop isolator which I may try before too deep into this.
I agree with @Bruce. Could be the quality of the amp. If the amps are wired properly directly to the battery with large gauge wire I doubt that a ground loop isolator will make a difference. A noise filter might however make a difference.
@Jim Robeson are the two amps different brands or models?
Are they attached to the battery in a similar way?
Based on my experience I am doubtful that a ground loop isolator will do much.
Yes, two amps and I'm pretty sure they are two different models. I don't know how they are attached to the battery yet...haven't gotten that far. Hell, I'm still trying to figure out what is hooked to what and what switch works what gadget :confused:
