Npbern
- SX
Hello everyone.
It's Wednesday for me. Monday night I pulled hte 2017 SX210 out to de-winterize it. Had a dealer winterize it, and I found a bunch of issues (who needs ignition coils bolted down?). Got to a point to start the engine. Hooked up the hose to the port engine, got it runnning, let it go for 10 minutes until it was properly warmed up.
Then the mistake happened. My neighbor stopped by and chatted, and I forgot to turn off the water. I finished getting the starboard engine going, and put the boat away for the night.
Tuesday (last night) I took the boat to my local launch, put it in, and couldn't even get the port engine to crank. I can hear the starter trying, but it can't crank the engine at all. Starboard started up without issue and idled happily.
I called my dealer and asked for service and they told me it's likely hydro lock from water back-flowing up from the hose.
The engine hasn't ever "Ran" after I unhooked the hose, I tried to start it, but that's it, no actual ignition. My plan tonight is to pull the plugs and try to crank it to get the water out, and do whatever else I need to recover it.
Couple questions: Obviously, I need to change the oil and filter. But, if it turns over, and I can get the water out, at what point do I risk trying to restart it?
Should I pull the plugs and, I dunno, shoot a hair dryer or compressed air into the spark plug holes to try to dry things out for a while? AT what point is it relatively safe to actually try to start it for real? Given this happened so recently, and the engine never started, I feel like I'm in not-the-worst case scenario here. Thoughts?
