Mainah
- Chapin, SC
- Limited S
Used Side tie model B 4400 lb with walkways. Set up for 2015-2020 ar240/242. Modified with 500 lbs of extra floatation (4900 lb capacity) and wireless remote motor/valve box attached directly to lift. Works good and has stood the test of several severe storms (with boat on and no damage to either) where others did not fair well. Requires about 4ft of water depth for operation.
Selling as will no longer be able to use lift at current location with policy changes at marina. This is not a small task to move over the road as it is almost 12 feet wide and 24 feet long. It can be disassembled and moved on a trailer but that is a chore as well. Local move by towing somewhere else on Lake Murray intact by boat is the preferable way to go.
Listing here first. Will post up on local marketplace in next few days as well.
Boat not included.
Boat not included.
