Rickala
- NY
I've developed a leak, I think primarily with the engine running.. Not terrible, but when I pull the drain plug, a few gallons comes out with the boat tipped backwards... Bilge comes on more often after I shut it down. I am wondering if it could be the inner bearing that's leaking, or something else... I did over-pump it with grease two years ago...I read a post from Cobra Jet that said you can blow it out.
I'd appreciate any advice on diagnosing this without using the shotgun approach...
