Tiger J
- Santa Rosa Beach, FL
- X
connected in parallel. Is this a bad thing? I always read to only connect “like” batteries.
Do you have a battery selector switch?
Two batteries without a means of isolating one from the other defeats the purpose.
If you are isolating them not good to have dislike batteries in parallel specially if your not isolating them at shore charging.
What he said ^^^^^^Different types of batteries store and give up electrons using different chemistry at different peak voltages and different rates. One battery will draw the electrons from the other weaking both through charge cycles. Even given two batteries of the same health the same will occur if in different states of health. Each battery only has so many charge cycles.
What he said ^^^^^^
In all seriousness get a 2 bank charger and minimum a perko battery switch and keep on rocking..
Engines will send a charge to both batteries which will be isolated by the switch.2 bank chargernia fine but what happens when you are runing the engine ....!?
Honestly, I'd rather use a deep cycle as a starting battery than use a starting battery as a house battery.While the deep cycle battery is not ideal for starting, I use it often for that purpose with no identified ill effects.
The engine will only charge the battery that the switch is set to. If you want to charge both batteries you have to set the switch to "both", but then you're back to your initial problem of having the batteries not isolated.2 bank chargernia fine but what happens when you are runing the engine ....!?
I drive and charge with the switch on both, then switch to aux if i want to play the stereo with the engine off.
You need to add an isolator or solenoid so both batteries charge if you want to just leave it on one. I use a solenoid on my rv.My fear is that if something inadvertently drains the battery, the switch was in both, so you have neither. That's why I'm always on one or the other unless I need both, or in on my way back to charge them both.
It seems there are many strategies, and all have some extra switch operations, risks and rewards.
Pick the one you like the most and can remember to apply
