- Rosebud, Mo
- 242X E-Series
I am just making sure I have this right before I go creating a potential heat rod on the floor. I am trying to figure out how to wire up my reversible ball valve ( driven closed driven open with limit switches ) so it works properly. I am going to use a DPDT ( double pole double throw ) relay so it just changes polarity for the ball valve. My Bluetooth controller will be my switch so I just need to tell it to switch. The ball valve will be in the closed position all t he time and then when triggered will drive open. When I turn the switch off the ball valve will drive closed. Clear as mud......thought so.
Here is my wiring schematic. Let me know if you guys see issues or a different way of doing this.
@trace @sstegh @KXCam22
