RobbieO
- Sacramento River Delta
- 212SE
Today when I was working on my boat on the trailer, I noticed a continuous whinning type noise in the engine compartment. Key on, both batteries on, float mode. It’s not the bilge pump or the blowers, goes away when I turn off the starter battery. Sounds like the fuel pump, but not sure. You would think the pump would shut off without a crank signal. It never times out, keeps running. My concern is when I’m in fliat mode on the lake this sucker is going to kill the batteries. This may be normal, but I think it should stop at some point. I let it run for an hour and it definitely was depleting the batteries.
Any ideas? Thanks….
Twin 1.8L 212SE
Any ideas? Thanks….
Twin 1.8L 212SE
