Yes tried true and tested ...but the 1.8s need a boost in displacement .. 2.1, 2.2 ... 180 HP and 360 HP .. .. outboard guys now have triples with 750 -900 HP ...thoughts ??
Unfortunately more displacement will mean more fuel burn. 2 1.8 liter engines is adequate for these hulls
You start putting more power on a hull like these that are pretty flat compared to the hull on a fast center console with twins, it could become unstable at high speeds.
You cant give these sterns too much angle because they will cavitate on the outboard pump on a turn.
I disagree. The 1.8's are workhorses of motors. They last a relatively long time between rebuilds. They produce adequate power for the application. Development cost of new motors isn't worth the payback in terms of power or efficiency. They work well, why change? Need a reason to change other than just for the sake of changing.
The exception being if they decided to go to a supercharged 2.0 engine. There are neat thermodynamic things that happen at 1/2L per cylinder in the right proportions. It's the reason you see so many of them in modern automotive applications. Good square bore dimensions (same bore as stroke dimension) leads to great efficiency, good balance, and great power. A 2.0T with a larger impeller (180mm-ish) would be interesting, although I'm unsure if it would lead to any appreciable gains over the current setup.
The speed demon in me always wants more power, but my bank account doesn’t like the costs of more power! I’m pretty satisfied though. My current family situation keeps us typically under 30mph. If maintained these 1.8s seem to run for a long time. I would have been interested in twin super charged 1.8s if they offered them when I bought my boat
I love those boats with massive twin blower motors, more research I’ve done the more I’ve released I’m not into rebuilding motors every year. I need to get some rich friends. Just a pipe dream but the new MTI 390x with twin 450s looks sweet.
The current boat market already has a lot of dumb/drunk/inexperienced people with boats, last thing they need is more power.
Another item most folks aren't aware of is that these engines are also wave runner engines and that drives a lot of Yamaha's development. Right now these are the largest displacement engines in the wave runner world. Yes, the BRP engines produce 300HP but that is due to supercharging which Yamaha also does and our Yamaha's are right at around 300HP also when supercharged. Kawasaki also hits 310hp but is also supercharged.
As mentioned, if you start increasing displacement you need to increase the pump and that will lead to other issues. The Wave Runners aren't going to go any higher displacement since they already approach 70mph in naturally aspirated form. When supercharged they surpass 70 mph and that is a boundary none of the waverunner manufacturers want to intentionally break because then the CG will step in.
I think the 1.8's are perfect for the boating we do. I was cruising around 35mph this past weekend with 7 of us onboard and had no issues in the bay.
The only "high power" boat that Yamaha hasn't built yet, but I REALLY REALLY want to see is a new 212SS. Get the 212X hull, lose the tower and ballast tanks to lighten it up a bit. Then throw two supercharged 1.8's in there with the 160mm (maybe 165mm) pumps. Would easily be a 65mph boat right out of the box, and with some tweaks (compressor wheel, tune, meth/water injection, bigger intercooler, etc) would be getting close in on 70+mph range. Would be a ton of fun to mess with the Baja guys in a little 21ft family boat
My next boat for the ocean will be twin 200+ outboards but I know that will require way more work than the 1.8s in my 212. 50mph in that boat is more than enough.
Come on Chevrolet, my impala needs more displacement. It's only a 3.6ltr with 200hp. McLaren is putting out sports cars with 720hp+ and I saw a twin turbo Lamborghini with 1400 wheel horsepower.
1. It's only money, and yes you could put that engine in your impala
2. Those cars are made to handle that horsepower and your impala would not be able to put it to the road
3. There is a reason why the average guy does not own that much HP, Darwin rules apply
So to put a dose of reality into this analogy, the Yamaha 425hp outboard for 2021 had an MSRP just shy of $30,000 each And in a non-covid market, that motor is now worth more than your 2013 SX240, let alone two motors of such hp.
So the reality of the power/performance that is put into an 8 year old boat of that value, which probably has had nothing done to it other than oil changes, I think most folks should be tickled with what they own. Bang for the buck is nearly unbeatable.
I'm with you on this one. I'm more than willing to spend more $$$ for more HP. I vote more displacement + bigger jets for more acceleration and top speed.
I think we have been over this in the past, HP is not the limiting factor, its the jet pumps ability and they are far from the most efficient way to deliver HP.
When I discussed with the Yamaha product managers the desire of forum members to get higher speed boats, their reply was effectively - "the market we serve is for family runabouts. Could we make faster boats - sure. But keeping standard parts across multiple models keeps pricing down and maintenance easy. Doesn't mean we won't make faster boats, but that there is less demand for +50mph boats than you would think"
We went on to discuss this more, but I get their point. I love to go fast in my boat on occasion, but if you pulled the hours on my boat, I'll bet I have less than 10 hours full throttle (out of 200-300). It EATS gas.
How about some nice high torque high mpg Diesels???? (wouldnt be able to sell them in CA!! but they have no water left anyway LOL)
Simple answer => buy a different boat/jet boat to suit your desire/needs. I did. I drive my boat like a drive my car; like it's meant to be driven. I love going fast but I never stay up there; just to dangerous. I feel, the thrill of getting to that speed is the best part. Both the boat and the car does this very well. But, driving at 55+ on my boat and over 100 in the car for extended periods of time, no thanks! That's just an accident waiting to happen. Plus, I can't afford the gas (boat)...
