Jeep7797
- Morris Illinois
So I have been out the last 2 days with my ls2000, Saturday I had an issue one time with the starboard engine slowly losing rpms and then it dies, thought I had a rope around the shaft or something so popped that port and it was clean. Started it back up and had no problem for the rest of the day for probably 2 more hours. Went out yesterday and after an hour or so of half to full throttle the same thing happened, Started fine again off I went for a few more minutes then died again. It would then start but I couldn't keep it running with the throttle. Limped back home a few miles on 1 engine and started looking into things. Couple things, I had all the oil lines done last year and have no issues with anything popping off oil related, I see nothing fuel related upon a visual, now it cranks over way slower than normal but the boats at my girlfriends house so I can't do anything without tools. I also had a good piss stream from that side the last 2 days so I don't think it was a cooling issue or anything either. My plan was to pull the plugs and crank it over to see if it's still cranking slow and if so is it safe to assume it's a piston ready to melt or severely busted up? I don't hear anything bouncing around in the cylinders like a broken spark plug or anything either. This is too damn early in the season to be waiting 6-8 weeks for a rebuild! Any suggestions guys?
