dan144k
- Palatine, IL
I went to replace my impeller in the fall and ended up replacing my drive shaft because the threads got chewed up during disassemble.
I have reassembled but not water tested, attempting verify my work I did was done correctly.
Another post I have shows the press I made with some threaded rod.
Hoping someone has better details or actual factory descriptions or pictures.
I have searched online and YouTube and found very little specific information
The (service manual) provided very little information regarding replacing the drive shaft, and also shows a simple picture of the two oil seals.
1. I went off old shaft and measured for pressing in the new shaft.
2. The oil seals had metal faces on both, trying to verify correct install and assembly
(I placed metal faces on the outside away from center Part 12,13)
-I think I assembled it wrong -they both should face toward the rear of the boat
-Also when I took seals out of the parts bags- I lost track of which went to which bag.
Thanks in advance for the help
I am sure this is simple for somebody who frequently works on these parts
