Ernie
- SX
Hey Guys I pulled out the impeller shafts today because I do get cavitation and wanted to check the impellers and housings. It looks like the Starboard side impeller housing has some wear so Im just going to replace both sides with new impellers and housings. The boat is 10 years old with about 160 hours on it.
I pulled off the bearing caps and there is no sign of water and there is grease in the cap but not much on the bearings. Here are a couple of pics so you can see what I mean. I may just take it to a PWC place and have them pull off the bearings to check and repack them. This is the port side but the starboard bearings look the same.
What do you guys think?
