Ernie
- SX
Hey guys, I hope you can help me out. I have a 2007 SX230 HO so I decided to pull out the impeller shafts to check things out since the boat is getting older. I pulled out the starboard side and everything looks good so I put it back and the shaft went all the way in and the housing sat flush so I installed the bolts and went to the port side.
I pulled everything out on the port and it looks good also so I put it back and for some reason I had to support the unit and push in and hold it there or it would pop back out a couple of inches. The only way to get the bolts in and tighten it down was to push inward and put the bolts in while I was putting pressure on the unit.
Do you think this is ok or is something not lined up ? Thanks for any help.
