jellyfishbone
- 212X
Greetings,
2014 212X rattling sounds at idle. I suspected the impeller impacting the housing, confirmed by getting my fingers on the stainless steel wear ring and feeling the slight scratches. Planning to pull the impellers and replace the housings, but wondering if someone here has direct experience with the WSM (or other brand) aftermarket housings with nylon/plastic wear ring. And curious how you know the plastic liner is damaged/worn if there is no audile indication..
Thanks again in advance!
