impeller removal rotation..?
Hector Corzo
Lynn, Ma.
I have a 2006 SX210 and I am trying to remove the starboard impeller from the shaft. to remove does it go clockwise or counter clock wise looking at it as it would be on the boat ?
Thanks for your help....
On my 2017 it was right to loosen (opposite of normal).. and I absolutely needed the special adapter to remove it...
yes, I have the adapter just wanna make sure I go the right way because I heard it was counter clock wise if you are looking from the front.
Heat up the threads before attempting prop removal. It can make a big difference. A propane torch is fine.
-Greg
