RobbieO
- Sacramento River Delta
- 212SE
Anyone replace an impeller wear ring in a newer model Yamaha? You can’t buy a housing with the ring, it’s separate. Wondering if it’s like replacing a bearing race in a brake rotor or if it has to be pressed out. I believe there are SS aftermarket housings available, but the munting bosses are not as robust. They might not even be available for the newer pumps. I’m going to order a spare ring and impeller, so I need to know the process. Replacing the impeller is the easy part. TIA
