Blazin14
- Elkton MD 21921
I have an AR230 with a stock MFI trailer. The tires on the trailer are wearing on the inside (camber). Need to replace tires every year. The front 2 wear more than the rear.
Has anybody else had the same problem and how did they fix it? New leaf springs? or did they need to bend the axel? (aka -Alignment)
What is the factory camber on a MFI ?
Can worn leaf spring cause a bad camber that causes inside tire wear?
It would be nice if someone had this exact problem before....
