tomcoombs
- Wellington, FL
- Limited S
So as part of the recent referb of our 242. I installed a Simrad G07 with a totalscan sonar.
It went in really quickly and looks great!
The head unit is on the center console right behind the wheel. Everything else is still easily visible.
I installed the TotalScan right on the rear, in the center on Stern Saver fixed above the stern drain plug. The cable came up and in through the Scupper drain pipe, exiting the drain pipe right at the fwd end of the engine compartment and then into cable chase with the steering lines at that point (very easy and quick way to get the cable in with NO EXTRA HOLES).
Wiring was easy too, I just plumbed right into the wires feeding the 12v power socket. It came with a 3am fuse and fuse holder. Very easy.
