4x15mph
- Downingtown, PA
Anyone install a second bilge on an lS2000 and do you have any advice on how you were able to get the thru-hull drain connected to the hose given that it is impossible to reach to the area by the 1st bilge outlet??? Any tips? I want to install a 2nd pump that has an auto switch since I don't want to have to depend on turning on bilge #1. IMO a bilge should be automatic
I have 2 options if I can't figure out how to get the reach to install the 2nd thru hull fitting
1) Replace the yamaha manual bilge (cycles every 2 minutes WHEN the switch is turned on) with the new, auto pump that I have. I would need to direct wire this new pump to the battery so it would always be on and that is easy. Downside is that I don't have a backup pump.
2) Put in the 2nd auto bilge and join it into the existing hose line for the 1st bilge. I see there are y connectors with back flow valves. I like this idea since it is simple. I am not really looking to have 1250 GPH and this is just about having a backup pump.
