Intake grate bolts
PrimaBoat
Bemidji, MN
Scarab
165 ID
Does anyone know the bolt size/length for the stern intake grate bolts (3)? Mine are missing (used boat purchase) The boat is a 2017 Scarab 165 HO.
Thank you! Do they attach to a plate of some kind or are there nuts in the bilge area?
Actually i believe the 3 bolt grates use m8 bolts
Two in the front, three in the back. It’s a long way to the hardware store so I’ll get both.
It turns out the three at the stern end of the grate are M6 x 16 bolts. The two at the bow end are M8 x 16 and bolt through the hull into nearly inaccessible nuts in bilge.
