Intermediate bearing Grease seal question
Alexegan88
252SE
Had service done at the dealer, it appears they overfilled the intermediate bearing grease. My question is on a 2022 252SE does this 100% mean that the seal is popped? Or is there an overfill relief valve or something like that?
My second question is what exactly needs to be replaced in order to fix it? What should I ask the dealer to replace? Are they going to have to pull the whole pump and engine out?
Appreciate the feedback
Take it right back to the dealer and get them to replace both of them.
Yes pumps need to be pulled, they should be able to move the engines forward to get the intermediate bearing housings out.
It needs to be replaced make them fix it and read my many posts about adding gear lube rather than pumping grease in them
What if there is no visible leak or water coming in? I spent about 15 hours on the water and did not observe any water intrusion. Is it possible for grease to leak through but not compromise the seal?
Well, I feel a little better, I was a bit worried because it’s been a few weeks since I had the service. Even though I noticed a little bit of grease when I first picked it up, I had no idea that it was a big problem, I thought it was just like overfilling a bearing buddy on your trailer, lol.
So I was afraid the dealer was going to deny responsibility.
I felt better because the service advisor apologized for the inconvenience of having to bring the boat up again and acknowledged that it was probably overfilled. He said even he had personally overfilled one on a jet ski in the past.
So now, at least I know they’re going to make it right.
So the dealer inspected it, indicated the seal was not compromised. They water tested it and said no water intrusion either. So they cleaned off the grease and that’s it. Like I said, I had already put about 15 hours on the water under pretty heavy use tubing and did not notice any water intrusion either so I’m guessing it’s fine after all. I still have the service document so if it does end up leaking or fails anytime soon, I’ll be able to blame the dealer.
Oh well sorry for your loss but the rubber between the housing and the bearings has been compromised and it will eventually fail those 2 parts are fused together and you can see where the hole is drilled through the rubber to the bearings , your picture shows the greaser separated the rubber and the housing from the grease fitting to the other side of the housing.1746283882251.jpeg
Your dealer sounds like a stand up place to do business with.. I’d be sure and “test” that bearing with a lot of hours on the water this season to make sure its good!
Any updates? How many hours this season ? Any leakage?
