Stevenpigsooie
- Beaver Lake, Arkansas
This has happened in many boats, without any ill effects. In theory, could indicate a blown seal in the bearing housing (not the bearing seal itself) but the only role for that grease there is to keep water away - so if there are no leaks there is nothing to worry about.Is this a leak? I didn’t notice any problems last season and never had water in the engine compartment. Changing oil today and looked around and found this on both engines.
Thank you for your response. Is this something easy to replace ? Or maybe tyhe question should be if this is something anyone can do or I bneed to take it to the dealer?Once it leaks you need to replace it a s a p ,water is entering in your bearing , do both bearings at the same time . If one goes the other is going.
Thanks again ! I am still covered by the YES warranty, will try to get them replace,Dealer or a mechanic that knows what he is doing .
I have a 2004 sx230 that has a leak now and I've done all the other bearings for these - is there any information you can direct me to on this site?That sounds like a very good idea. I have done several and it's a lot of work.
