Ozark
- 195S
I have a 2021 195S that I purchased new earlier this year. I performed the 10 hour service which included greasing the intermediate bearing. I used my grease pumps owners manual to calculate the number of strokes to not overfill the bearing. Today, I noticed the seal appears to be leaking grease. When I wiped it off, it was mostly the yamalube I added, but another tan grease was on the rag as well. Is the leaking lube a sure sign that the seal is toast? Or should I put the boat back in water to see if its leaking water into the hull? I am still under factory warranty until 2/2022.
