BobJohnson
Jetboaters Commander
- Highland Park, il
- Chaparral
- VR
Want to make sure I get my boat ready for winter the right way, not just the easy way. Rotax engines are close cooled with antifreeze, so the water I need to get rid of is just in my exhaust. I have come across 3 different methods for getting the water out and would love to hear your all thoughts on the different methods.
1. out of water, start and rev engines for no more than 20 seconds to blow the water out of the exhaust.
Pros - easy, clean, no other equipment or tools needed.
Cons - can't or hard to tell if all the water is really out.
2. pump anti-freeze into exhaust system in order to clear it of water and replace with antifreeze. Then rev engines to remove the anti freeze.
Pros - if anything is left in the system, it is antifreeze
cons - not crazy about having antifreeze pour out onto ground while flushing system. Costly. Need pump?
3. Attach pressurized air to the exhaust system up to 100 psi and blow the system clear of water.
Pros- should clear system well.
cons - I don't have a air compressor, so would need to buy or find one to borrow. Also, blowing up to 100 psi of air into system, worries me. just feel like to much pressure could cause harm. to little pressure might not get all water out.
So - # 1 is my prefered option, if it is satisfactory. Around here we can easily see below zero weather for extended periods of time during winter. Want to make sure I am doing the job right, just to easy.
Please let me know your thoughts and what you do.
