Trm1765
Jetboaters Commander
- Red Wing MN
- Limited
The statistics that where mentioned earlier seem irrelevant to me. Here is my two cents worth on to spend money on plug locks or not, even if I exaggerate the numbers... if only 1 out of 1 million plugs blow out, but plug locks of some type guarantee that I am not that 1 that does blow out, then I should spend the 30 bucks on the locks. That is cheap insurance.
It doesn't matter to me what the cause of the blowout is, operator error when putting in, mechanical error of the plug itself, design problem, it doesn't matter. The locks take to problem away, completely.
I see all pro and no cons adding plug locks. They are easy to install the first time, (5 minutes) they are easier to install for everyday use, (seconds) they are easy to take out, (seconds) they don't effect any warranties, they are cheap, and they guarantee no plug blow-out.
And if there is a limit on money or time, adding plug locks is way easier and cheaper than adding second bilge pumps and some of the other options I hear people doing in case of plug blow outs.
