Expedition_Recreation
- 242X E-Series
Ok so here we go....
Like many of you we recently purchased the lateral thrusters as well as the XV vectors. We have been extremely happy with the lateral thrusters (as they came first) however now that the XV vectors are installed I have run across more than a few odd issues and I am hoping some of you had some experience with.
The first thing we noticed that was a bit strange was the instructions to flip the bolt upside down on the steering linkage (pictured below). If it would not have been flipped it would not have touched the spring but now that is has the spring touches the bolt. This may not have any negative impact on anything but it seems strange. Can anyone clarify this for me?
The second thing I ran into was the cutaway fin hitting the rod that runs from the articulating keel when turned all the way. It doesn't affect it much but it does limit its turning ability a bit. I thought maybe I could have potentially installed it wrong but after reinspecting all of the components I realized that there is no way I could have done anything incorrectly.
The last issue we are having is with the sacrificial anode on the starboard side. Apparently it is a known issue on the 18s and when turning the steering wheel all the way to the left the bolt on the left side of the XV hits the anode. I was sent bolts and used the extra spacers included in the kit however the bolts they sent me seemed to be the same length as the factory ones and even when spaced as instructed the bolt on the XV still hits the anode. Depending on the angle it will allow it to pass sometimes however it definitely still clips the edge of the anode.
While none of these issues are major (I dont think) we were a bit surprised after taking the boat out and testing it out a bit. The steering seems to be binding more than expected and you can definitely feel the resistance when turning the steering wheel. As others have mentioned I also noticed the wave being less clean behind the boat (as others have mentioned on the forum already) but not bad enough to where I would consider it a problem.
I am very happy with the performance gains from these products however I feel like the steering binding in a couple places is definitely an annoyance and is more than a little annoying when turning the steering wheel back and forth. Anyone have any feedback or suggestions?
