Jet nozzle play? How much is normal?
Luc Lafreniere
Staff member
Scarab Forum Lead
Ottawa, Canada
Scarab
165 G
I don't think I have an issue, but it does wiggle a little bit. How much play should there be? 165 model in case that matters.
they need to float , when the water is blasting through the nozzle it will be tight. grab ahold of a Yamaha nozzle and you will see the amount of play those have built in even more that the 4 tec
Ok excellent. I figured it was supposed to wiggle a bit. It only moved a tiny bit. Thanks
Can't have it tight so you are just fine
