FSH 210 Sport
- Tranquility Base
- FSH Sport
Two years ago I service the grease cones on my boat, I was behind one year on that service (boo FSH 210 Sport Boo). I remember the first time I pulled the cones that I thought there was not enough grease in them to be able to migrate up into the bearing carrier and into the front bearing.
Here is what they looked like in April of 2023 after I had serviced them in 2021. I had filled the cones up about 2/3 of the way with grease.
Port
Starboard
When I serviced them in 2023 I filled the cones up with grease after much thought and research, again my thinking was to make sure the epnoc grease was getting all the way up to the front bearing.
Here is what they looked like when I pulled them a couple of weeks ago in December of 2024.
Starboard
Port
Interestingly the port cone was still totally full of grease while the starboard cone had developed a bit of a void and a tiny bit of moisture in the grease.
So, being the way I am I went back and had another long look at the service manual to double check things. The service manual states .7 ounces for the space in the bearing carrier and the cone. For reference the cone will hold just shy of 5 ounces, so .7 ounces would be a drop in the bucket in those cones.
I called my “local” dealer in Bismarck to ask a mechanic what they did when they service them. The mechanics were off, but the service manager Tim said he would check with Yamaha corporate and get back to me. About 10 mins later he called me back and said that Yamaha said to fill them with grease.
Hope this is helpful
Port
Starboard
Starboard
Port
