zachholmes02
- LS
Hello! I have a 99 LS2000. I am rebuilding one of the pumps and I'm having an issue. I believe my clearance "A" on the diagram attached is wrong which is causing my issue. The last seal with a smaller ID is getting pushed out and the rear bearing looks like it is too deep.
How can I fix and remove the inner bearing without damage? Is it possible? Is this my issue or something else? I assume others have ran into this problem too. Thanks!
I'm sure it was from having an inadequate gap originally and mainly from pressing the outer race of the rear bearing too far that it pressed the whole assembly to the pump housing lip.
