jet pump noise
robertr
Miami, FL
SR
So going over the boat before I get it on the water for the first time. I am hearing some rattling noise from starboard jet pump,I'm gonna grease the intermediate housing as I just got the boat and who know if its been greased, is it usually the bearings in the impeller duct housing that go bad ? I'm gonna remove the cone and check the grease and probably take the impeller out and check the wear ring, If I take out the assy and spin the shaft , it should spin smooth and no play correct?
thanks
Although this isn’t a reply to your question about the free spinning impeller, if you’re new to this boat, I would encourage you to get some advice from folks regarding greasing the intermediate bearings before you do that. Just wanted to caution you.
thanks, I've done some research on it, but open to suggestions and advice,:thumbsup:
Out of the water the impellers will rattle and clang. But due to the age of your boat and the salt water, I would pull the pump and check the bearing under the cone.
gotcha, will definitely check them
D9A053D0-E013-4492-818D-2A30065DE77C.jpeg821385B9-1066-4D85-B9D3-652A7B3CD39B.jpeg5BFA5D3D-5A5B-4FAA-AD50-A8BEB20BD19D.jpegA7322A13-5499-4DB4-889E-AFD979116B83.jpeg1D1556CE-6398-4596-9239-08B97F6294A2.jpegD9A053D0-E013-4492-818D-2A30065DE77C.jpeg821385B9-1066-4D85-B9D3-652A7B3CD39B.jpeg5BFA5D3D-5A5B-4FAA-AD50-A8BEB20BD19D.jpegA7322A13-5499-4DB4-889E-AFD979116B83.jpegF60DB5F4-B348-49CB-849E-24C1E50C3F88.jpeg1D1556CE-6398-4596-9239-08B97F6294A2.jpegS
Starboard pump, surprisingly everything looks great, no water in bearing, wear ring looks brand new , impeller looks brand new, no play at all, this side is good to go I think
IMO - Based on the darker color of the grease, the bearing looks like it has water contamination. Wipe the grease off the bearing and see if the steel has discoloration or rust spots. If it does, I would say your rattling noise is from the corrosion on that bearing.
Might be the pics, bearings look good to me, no noise or rust spots,
How is the clearance all the way around the blades and the wear ring? Even?
It looked fine, Even spacing, haven’t done the feeler gage test, but no marks on the wear ring
could it be that they added the amsoil lube ?
Pump looks pretty healthy to me for a 17 year old boat. Impeller is dinged up a bit but not too bad. While you have it apart consider switching over to an oil bath on those bearings. Search @Bruce for his write up on doing it.
You can't see the other bearing on the shaft but I have not heard of the unseen one failing. Just the one you pictured.
I guess you better check the intermediate bearing behind the engine.
yeah, im planning on the doing the oil bath as per Bruce, some say they make some noise out of the water , hopefully it was just that, guess I should look up how to check intermediate bearing
So what did you find out or end up doing ?
Your boat is 17 years old...how many hours are on it?
When my boat was brand new it was making a metallic noise when running on a flush hose, and it still does. IMHO what you were hearing was the play of the components rattling, you don’t hear it in the water because the impeller, the bearings, shaft etc are all under load while idling in the water.
Thanks for the pics of the bearing and impeller.
When greasing the intermediate bearing next to the engine bulk head, use a light touch with a manual grease gun with the correct water proof grease. As soon as you feel the resistance increase in the pump handle of the grease gun, stop.
I agree , I took everything out , put Delrin liners , took the cones off , did the oil bath mod from Bruce, greased the intermediate bearing, been running perfect ever since, the noise is still there. But it’s ust the usual rattle when out of water and flushing with hose , if you are not familiar with these boats it’s a little concerning at first , but so far running strong
Thanks
Thanks
Thats great news! I had the same butt clenching reaction when I heard that noise the first time and I had not discovered this web site as a resource yet.. luckily I have a friend who has a lot of marine experience and he educated me on jet pumps...
So how many hours are on your boat?
About 380 right now I believe
