topherbd16
- Marysville, OH
- 212X
Two issues I'm having when towing tubers.
-Rope is mostly underwater
-Jet spray makes it annoying for those tubing.. I've gone to 70' and still they are sprayed and wear goggles to tube.
My '18 212X has a very low tow point connection for tubing, maybe 6" above the lowest rear deck (below rear seating area). I don't attach to the wake tower, even though I see it by others quite a bit. I'd hate to crack my hull or tower.
Those with higher tow points and/or I/O props don't have these issues.
Buying the Booster Ball is an option for the rope being higher and out of the water... but it's one more thing to lug around my prop friends don't need.
How do you reduce jet spray? Is the Thrust Vector Wake the only option?
This just seems to be fundamental problems w/ this boat. Tow point is too low and Jet boats have spray.
Yes, I'm frustrated and looking at other boats, but not giving up just yet if I can find a solution that doesn't take so much time each trip out or cost a ton of $.
However, if you really want an '18 212 w/ <70 hours, Wakebooster, upgraded to 31 AGM batteries, additional ballast and tsunami pump... let me know. I'm kinda serious.
