Camson
- Rockport, TX
- FSH Sport
Finally got all my parts delivered for my audio update. I will be using stock head unit, 4 - JL Audio MX 650's, 1 - MX10IB3 subwoofer, 1 - JL M800 amp.
As for part list, I basically copied orexismd install and he has listed the equipment needed so here is link to his thread which has much better details. The only real difference is I used 4 gauge wire from battery to helm and instead of using two amps, I went with one larger one. https://jetboaters.net/threads/fsh-210-sport-audio-upgrade.22347/
I would like to add two more speakers in back of boat but not sure yet how to gain access like orexismd
I ran 4 gauge wires from battery compartment to engine compartment and then over fuel tank and directly to helm. Not hard at all and only one hole between engine and battery compartment. I used gray split wire tubing for the battery wires
Engine compartment where wire runs into battery compartment
Used hole already from engine compartment to fuel tank compartment
Looking at gray tubing above the fuel tank
As you can guess my theory is to run more cable than not enough. I had plenty of wire left over.
