Keelan4604
I just bought another AR230, knowing it was broken, with the intention of fixing it. It was advertised as needs new ECM on the port engine, which is definitely true but not the whole story.
The story I heard from the buyer, who I still believe to be telling the truth, or his version of the truth, goes:
He's had the boat for 4 years. Gets all maintenance done by Park Marine near Atlanta. Boat sits for winter. Takes boat on water, and oil light comes on port engine. Limps back to dock on starboard. Takes boat to Park Marine, where they diagnose bad ECM and do an oil change on each engine.
Looking at the boat today, I found a few different problems, and can't seem to figure where they originated from and what exactly they are. Both engines start and run, no lights on the dash. They both start up quickly and idle okay. The port engine was hissing when I bought it, from an injector dumping fuel (possibly because of the ECM). The starboard was seemingly fine when I bought it, but I wasn't paying close attention to an open injector on that engine. It ran fine, and I chalked it up to good the engine is fine.
Getting into the boat further today, I find a nice assortment of electrical problems all around the boat. Whoever had the boat before the guy I bought it from invested substantial money into the sound system, lights, solar panel, etc. However, the wiring done to install these systems is definitely questionable. To start, there are two batteries in the back, for starting the motors, and one battery in the front, for the sound system and presumably other accessories. The accessories wont turn on, which wouldn't be too weird considering the suspected dead battery, except for the fact that all rocker switches turn on docking lights instead of their assigned accessory (i.e. bilge, blower, horn, dash lights all turn on the docking lights and nothing else. In addition, there is a short circuit somewhere on the front battery and stereo amplifiers, causing fuses to blow the second I put them in the amp. It is worth considering that this boat was regularly parked outside, getting absolutely flooded with rain, however, no signs of corrosion or water damage are anywhere. Seller claims that he has never had electrical problems like this.
As far as the engines go, they both start and run fine. Now both engines have at least one injector dumping fuel, as well as the breather boxes being substantially full of an oil/gasoline mix. It is also worth noting that the substance in the starboard engine's airbox has a milky color to it, whereas the port side does not.
Does anyone have ideas where these problems could have originated from? Could they all be interconnected? I am beginning to suspect that someone overfilled the oil on both engines, causing oil to spill over into the airbox, shorting the injectors, frying the ECM's. Not sure if that's exactly possible. It's also worth nothing that the fluid in the airboxes is great enough in volume to submerge the injectors completely as well as their connectors.
Let me know if anyone has ideas to what could have happened, and potential fixes/ what my next step should be in fixing these motors. I would rather not buy 8 injectors and 2 ECMs if possible.
