1BadTundra
- 212X
I'm the second owner on our '16 212x, and just pulled the engine anodes, for what feels like the first time they have ever been out. First, what a bitch to get to and articulate my big ass back there... Second, man were they rough. They looked like an old car battery terminal with a lot of buildup. I wire brushed them down and used 400 sandpaper to make them good and shiny again. Yes, I know they are cheap, but with a day off (finally) and no parts on hand, I at least wanted them cleaned up. Fresh and clean with fresh silicone on the seal, I reinstalled them.
This has me thinking, if they were that corroded, what do my water jackets look like? Is it safe to pump in some CLR, Coca-Cola (works for battery acid) or something that will breakdown that galvanic corrosion? Do they make anything to clear the water jackets?
One engine at idle trickles water, while the other pushes it out the pisser stronger. At Higher RPMs, they both flown good. Both water pumps are new-ish, and the impellers look good. Just wondering if I have a blockage in the cooling passages, now after seeing the anodes, I'm concerned a little more.
