WildBillF1
- Bullhead City, AZ
- SX192
I'm a new guy here, but learned lots of valuable info on this website regarding the SX192 before making the purchase. I love the new boat, Yamaha has made some huge differences over the course of 17 years. I just have 3.6 hours on the new boat, so still a lot to learn. I knew I was going to sacrifice some performance going from 2 jets @ 270hp, to one jet @ 210hp, but wanted a new boat that would fit my standard 2 car garage. That LS2000 was a rocket and handling it through full throttle turns was a lot of fun, in that regard she'll be missed.
For the SX192, I've read the threads addressing heat soak, bigger intercoolers and the ribbon delete. I've got a 4 year Yamaha warranty, so not certain if/when I'll start with the mods. I have already experienced the same thing everyone else did after engine break-in, 42mph @ 7200rpm.
Anyway, a couple of quick questions from the new guy.
1. Since higher octane fuel burns cooler, is there any noticeable performance to be found by using premium?
2. On the LCD screen, is there some kind of trick to get to the "More" section? The owner's manual says to push the M&T buttons simultaneously, but that rarely seems to work.
3. Engine compartment is extremely hotter than I was use to, but water coming out of the pee hole is cool to the touch. No alarm was triggered, do these engines just run that much hotter?
Thanks in advance!
Out with the old...
In with the new...
Thanks in advance!
Out with the old...
In with the new...
