What size keel guard are you guys using on your 19 footers? Also, any recommendations on brand, I see on amazon they have KeelShield by Gator Guards and KeelGuard by Megaware?
i don't know what the manufacturers recommend for a 19' boat but they do recommend a length based on boat size. I just added 2' to the recommendation as I mine start just under the anchor locker drain, not lower.
I've had both products and they are essentially the same but the keel guard has ridges that run the length of it where as the keel shield has chevron shaped ridges that go side to side along its entire length, the ones I have and had anyway. Also the keel shield I had was white but yellowed within two years of install so I went with off white when I got the keel guard.
Got it installed yesterday. If I ever had to do it again, I would get the 9', in my option that would be the perfect size. But the 8' fit very well, good coverage
FYI- I just ordered a 10’ keel guard to replace a 9’ that was removed to change the color. My guard starts just under the bow ring, I went with the extra foot to protect that part of the keel that much better in case I beach anywhere with a steep drop off. I think the mfg recommends 8’ for a 21’ and 22’ boats and 9’ for 23’ amd 24’ boats.
So far I’ve had a white keel shield that started to yellow, an off white keel guard and soon a black one, black to intentionally contrast with the white hull. Surprisingly the black is a little less expensive than the white version, my pre tax and shipping cost was $206.
Depends on what you are after, more keel protection or a “better” look/view/presentation of the keel guard. It’s a classic function v form situation. I think megaware recommends that the guard be installed so that it starts just above the water line but if you want it close to the bow ring you will need another foot or so to maintain the same coverage as if you followed megawares recommendations regarding length and installation.
I’ve taken measurements before ordering in the past an just estimate the maximum length of my keel is in contact with the shore when I beach my boat. If I think I can install the recommended length near the bow eye and still protect the keel adequately that is the length I would buy. If you already have scratches from beaching get a length that will at least cover those scratches which also meets your installation location requirements.
Isn’t the price delta around $30 to $40? While nothing to blow off, $40 would only put about 10 gallons of gas in my tank here in NorCal and is nowhere near the cost of my insurance deductible if I took the boat into a shop to have the keel repaired (actually from a time perspective Unless the shop was next door, if I made just $13 per hour I would lose a more money if I had to take the boat in and get it back from a shop).
Agreed, my boat is still in storage and we getting 2 to 4 inches on snow today. I guess I will just have to patiently wait until I get it out of storage. I found a 8’ for about $70 cheaper but I only want to do it once. $70 for a foot, just irritating.
I would have gone about 6" higher towards the bow of the boat. Sometimes when riding in choppy water, I get a small amount of spray from the front, coming from the keelguard. Never had any spray before installed. It's minimal, just slight spray on the front seats when going fast over rolling waves. I don't think I'd have any of that if I had it higher in the front. Mine is about 6" above water line when not moving, but dips below when going through waves
This is all from memory from last season, I haven't taken my boat out of storage yet, it was snowing yesterday
