Amar Nanduri
- SeaDoo
- Challenger
Yes. Water will be absorbed into the fiberglass unless you seal it.The keel guard will cover up this area. Is it still necessary to patch up the fiberglass before I apply the keelguard ?
Pardon my ignorance. Isn't the keelguard waterproof ? Nonetheless I will repair the fiberglass before I apply the keelguard.Yes. Water will be absorbed into the fiberglass unless you seal it.
Not the bond between the rubber and hull. Water can and will penetrate through the glue layer over time.Pardon my ignorance. Isn't the keelguard waterproof ? Nonetheless I will repair the fiberglass before I apply the keelguard.
Thanks
Amar.
Thank you so much for the info. Do I need to take it to a dealer to get it repAired? Or is it someth No I can do on my own ?Not the bond between the rubber and hull. Water can and will penetrate through the glue layer over time.
@Amar Nanduri, @Murf'n'surf is correct in that you want to fix the damage prior to installing the keel guard. You can get two-part marine epoxy from Home Depot or similar stores. It's tough as nails and will be difficult to sand and smooth out (harder than the gelcoat so be careful not to sand through the gelcoat while smoothing out the epoxy), so keep this in mind when you're applying it. If I were you, I'd give the surface a good cleaning and a final rinse with isopropyl alcohol so that it is clean and dry before you apply the marine epoxy. Put the alcohol into a spray bottle and spray it on and brush it in with a toothbrush, then give it a final spray/rinse. Take a hair dryer
You want to repair the area for two reasons: seal it up so that there is no chance of water wicking into the fiberglass, and so that the contact surface is maximized between the keel guard and the hull for maximum adhesion.
When you're applying the keel guard, take your time. I used a small paint roller (3" long) to help with the initial contact (to tack it into position so that it stays straight) and then I used the spatula that comes with the install kit to apply max pressure for contact/adhesion. The paint roller idea came from a technique that is used when vinyl laminate is applied to mdf, where a hard rubber/nylon roller is used to compress the two surfaces together.
Good luck.
Not to alarm you ..... but I wouldnt try to use that stuff.Thanks everyone. I purchased the Marine-Tex mighty repair kit. Will give it a shot and see how it goes.
https://www.amazon.com/gp/product/B001446LMW/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Best
Amar
