MutherTuckersMan
- Shelbyville, IL
Getting the boat ready for summer. The boat had sat in storage all winter; batteries were not hooked up to a tenderizer. The house bank comprises of 4 Kinetik HC 1800 Blu batteries. Perco switch was set directly to this bank upon charge. I was able to pull some juice to the stereo but my volt reading was low. A charge had been applied multiple times but to no avail. I disconnected all for batteries and attempted to charge each one separately. Out of the 4, I was able to bring one up to a full charge; the other 3 would not. They would read "bad battery" on the tenderizer and on the portable charger they would read full charge with no volts. I did some research on the new smart battery charges and found that if the battery doesn't pull enough amps the charger will actually kick out. I switched to an old school battery charger to bypass the smart system but no luck. My questions are: 1. Are there any other alternatives I can pursue to try to get these batteries to hold a charge or are they simple junk? 2. Replacement batteries...what does everyone recommend?
