Ladder weight limit?
Marvin willis
Morehead city nc
Anybody know the ladder weight limit? Got a family member that is huge and don't think he will be able to get in my boat (not my problem). Just curious though. I know it will hold 300. Just do t know how much more.
If he does use it which I don't recommend, make sure he doesn't push forward with his legs or he will bend the ladder under the boat. Even regular sized people need to be careful.
I suggest you check windline's site. I bet they have fielded the same question many times already.
https://windline.com/index.php?route=common/home
I didn't see specs on the site but I didn't look hard. Also, I've called them before so I think that would be the easier way to get the info. from the most reliable source available.
Hmmm, you have an AR.....ever thought about installing a hoist?
Lmao. He would break it. He's 500lbs. Suppose to b getting surgery soon but he isn't getting on until he drops a couple hundred pounds
