Leaking Anchor Locker Fix
Tailwaters
St Joseph MI
I would appear to have the very common anchor locker leak issue. Happen to stop by the local marine store and ran across the perfect fix for the problem. Turns out to be the same size diameter as the original (cut to short fitting). Should be an easy install
Interesting. Who's the manufacturer of the part, what's the P/N? Post pics and let us know how the install goes!
Any update on this? Got the part / manufacture number? Tks
The place I purchased this from had no part number available. However here is a link with a better option. I'm planning on replacing all my plastic through hull fittings with stainless ones over the winter months. Here's a link to what I have in mind for the anchor locker. Should be able to cut this to length. Last year I accidently hit the through hull pee fitting with the scrub brush and it snapped right off. I've since decided I prefer something a bit more durable. The link below has several different options.
