4x15mph
- Downingtown, PA
Started the engines today for the first time to prepare for the season. Both engines started although I noticed gas leaking from the one of the carbs of my port engine. I have isolated the leak to the areas with the arrows in the attached pictures. where the gas line goes into the 1st carb of the rack was suspect so i tightened that brass fitting. That didn't fix the problem.
After pulling off the flame arrestor etc, it seems like the leak might be from the gasket where you will see the 2nd arrow. I rebuilt these carbs last year using the SBT rebuild kits... is that coming back to haunt me?
Any advice on next steps or experience with dripping carbs? I am thinking I will rebuild this single, leaking carb with a genuine mikuni rebuild kit and replace just the gaskets, rubber seals, and diaphram.
I have to mention that I do have the electric, groupk air/fuel separator so my fuel is under pressure which may be adding to any carb gaskets giving out but I am afraid it may be an SBT thing.
![IMG_1186.JPG IMG_1186.JPG](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/34/34637-1bec1968004dba325bc41ddb9b6281e3.jpg?hash=G-wZaABNuj)
