Judge
- Cape Coral, FL
- 275SD
I need some opinions from guys already running the Lectrotab Trim Tabs and have experience with their performance on the Yamaha's as it pertains to trim tab size.
I have read just about every Lectrotab post and most guys say the tabs are super responsive and only 1 - 3 LED's need to be lit on the controller to get the benefits desired at various speeds and sea conditions. At least one or two guys thought they would have liked to try smaller tabs or even mount them so they are a little higher from the water.
I'm installing them on a '22 275SD and originally planned to install a set of 10" Deep x 14" Wide stainless heavy duty tabs. Unfortunately the boat has underwater lights that are creating some challenges.
If I were to install the tabs against the lights, it pushes the tabs further out towards the chine and causes the actuator to get pretty flat or close to parallel with the tabs because the angle between the swim platform and transom gets pretty shallow the closer you get to the chines. This makes it more difficult to get the 1/2" above the hull bottom adjustment for the trailing edge of the tab whem the actuator is fully retracted. I also worry about the actuators pushing in more towards the transom than they try to push down against the tabs. I also run into challenges with the tie down straps and I'm also dry rack storing the boat so have to be worried about the forklift coming in to lift the hull.
If I try to move the tabs beneath the underwater lights, I can't get the 1/4" of space I need from the bottom of the hinge to the bottom of the hull. The hinge will be at or just below the bottom of the hull. The port side is closer to working but of course the guy who installed the starboard light mounted it 1/2" lower than the port light... go figure!
Mounting the 10 x 14's under the light give the actuator a much better angle and the adjustability I need for the tabs to get the trailing edge 1/2" above the bottom of the hull.
So here are my options:
Option 1 - I mount the trim tabs to a piece of plywood and then use a carbide hole saw to cut a partial circle (about 1/3 of a circle) out of the mount that is about 2" long and 1/2" deep so I can mount the tabs higher by positioning the tab mount up around the bottom of the light . I spoke with Russ at Lectrotabs and he said cutting a notch in the mount is a reasonable approach and he had to make some custom tabs for another boats to deal with underwater lighting. But cutting 1/8" stainless will be no fun.
This option allows me to use the 10 x 14 tabs I had made and mount them in a position that gives me the best adjustability for the actuator. It also eliminates issues with the tie down straps and reduces concern of damage by the forklift when moving the boat to and from the rack.
Option 2 - I ordered some 9 x 9 tabs from Amazon because I could get them in a day for comparison purposes and then return them if needed. The 9 x 9 tabs could be mounted next to the lights and still give me a decent actuator angle and adjustability when mounted under the swim platform. I would still eliminate issues with the tie down straps and reduce concern of damage by the forklift when moving the boat since they are not as wide.
The downside of this approach is that I go from 140sqin of surface area down to 81sqin of surface area. Everything I have read from most trim tab manufacturers says you want the biggest tabs you can fit.... but they also say that there is not a one size fit all approach because there are so many variables from one boat / hull type to another (including Russ at Lectrotabs who says some boats don't need them or are on the ragged edge of needing them or some boats are more responsive to tabs than others).
I also read the faster your boat can go, the smaller the tabs that are needed so boats that can cruise over 40 knots can get away with smaller tabs. However, slower moving boats need bigger tabs to have an impact.
When I spoke with Russ about the 9 x 9's he said while they don't recommend them for a 27' boat on their website, it doesn't mean they won't work and provide the benefits. He said instead of needing 2 or 3 LED's of input, I may need 3, 4 or 5 LED's with the smaller tabs. He also said he could make me a set of 9 x 9's (or 12 x 9's) in two days if I went with aluminum instead of stainless (but I prefer stainless since I run in salt water and it's a bigger boat).
One of the main reasons I'm adding the tabs is because I boat in southwest Florida in the Gulf. When the seas start getting 2 - 3' or more of chop, it will be nice to run slower but keep the bow down and stay on plane at slower speeds to deal with the rougher water.
My concern with the 9 x 9's is whether they will be too small and not provide the benefits at slower speeds in rougher water because they could be too small struggle to lift the stern enough to keep the bow down. They will also only be positioned in the center of the transom between the jet and the chine where the 10 x 14's will run from the furthest left side of the transom under the lights about 3/4 of the way to the chines (and there is clearance when the nozzles are hard-over).
On the flip side, guys who have installed everything from 9 x 16's, 9 x 12's and 10 x 14' tabs on 21 to 25 foot Yamaha's seems to agree that more than 1 - 3 LED's of input is all that is ever needed.
So after all of that background.....
Do the guys with the Lectrotabs installed think a 9 x 9 could be enough for a 27 footer or do they think I would be better off modifying the 10 x 14 tabs to make them work as originally planned?
No one on here has put trim tabs on a 27' Yamaha with a 9' beam yet or one that will weigh around 7500 - 8000lbs fully loaded so I'm going to be the first.... but there is a lot of good experience on this forum that I value.
Please let me know your thoughts when you can. I need to make a decision and get them installed in the next few days.
Thanks!
Thanks!
