atompa
- Michigan
- SX
All,
I'd like to start by saying that I'm not trying to make ANOTHER LED install post, I apologize if this morphes into such.
I'd like to focus more on the, WHAT, not how. The equipment, not a walk through.
1) LED lights- what 'quality' did you use? How many LEDs/Meter is 'enough'? eBay has great deals but I'm scared that they aren't intense enough.
2) did you solder or use waterproof quick connects after cutting?
3) switch install - what type of switch? Do you like where you mounted it? I may attempt to replace the factory JVC remote with a plate to house new switches. Either that or by the throttles.
4) did you use the jumper approach similar to the factory wiring?
Sorry guys, I guess it did morph into a how-to.... :/
