Led switching noise thru speaker
Jose galvez
Miami
Have an issue. I installed and led set in the boat. They work perfectly but I'm getting a noise when they switch from color to color thru the speakers. Tried changing the ground from it location but still keep getting the noise. Any ideas
Make sure your stereo is grounded to the same ground as your amps. Everything needs to go to a single ground. Otherwise you get a ground loop. If that doesn't work try buying a ground loop isolator on Amazon. They are about $9
I had the same issue so I bought a different controller and it took the hum/noise away.
