We were thinking that might be the issue - will replace ASAP!Do you have the original scupper valve?
I don't get this...even if the valve was letting water into the scupper tube of the boat, the valve is well below the deck of my boat and couldn't travel back uphill and fill the boat. I don't see how water could get that far and fill the deck area.Do you have the original scupper valve?
Not the scupper valve. On the older boats, the scupper hole is at or below water level. When on plane, it’s out of the water. The actual plastic fitting cracks and the thru hull fitting leaks directly to the bilge. So, it’s not leaking into the hose and thru to the deck per se. (if that makes sense)I don't get this...even if the valve was letting water into the scupper tube of the boat, the valve is well below the deck of my boat and couldn't travel back uphill and fill the boat. I don't see how water could get that far and fill the deck area.
I would think there might be a leak around the jetpump housing where water could fill the bilge area and lower the center of gravity of the boat and continue to take on water. At that point a leaky scupper would be an issue too.
Was your bilge pump on?Left the boat at the dock, came back this morning and it was filled with water barely afloat. No issue with the plug. Any ideas?
Ah, I get it now, thanks for the info.Not the scupper valve. On the older boats, the scupper hole is at or below water level. When on plane, it’s out of the water. The actual plastic fitting cracks and the thru hull fitting leaks directly to the bilge. So, it’s not leaking into the hose and thru to the deck per se. (if that makes sense)
Last week my new to me SX210 was floating on my buddies dock. The scupper valve with out warning just failed by breaking between the outer flange and the inner section of the tube. Thankfully my buddy was on his dock and heard the bilge pump throwing water out. By the time he pulled his boat off the lift and pushed mine onto the lift water was at the bottom of the engines. So much water the forward holds were full. It filled so fast if he hadn't been there it would have sunk. I'm sure there is a good reason but having a 2 inch PLASTIC scupper valve below the water line is silly. Now has a stainless valve and not a particularly fun job to replace.
