NeoBrew
- FSH Sport
I don’t use my live well very much. (210 FSH). I’m on a trip right now and noticed that the bilge pump is running a lot. Had this before but assumed it was a drain port, anchor locker, or that I didn’t have the drain plug o-ring seated.
A little investigation revealed that the live well filler line has a small port on the elbow going in that is just pumping water into the bilge.
There is a small tube that leads up to the black “max air” port just above the live well. It is not connected to anything at the bottom. Is this supposed to be on that port?
Any tips on how to get in there and fix it? I was able to take a picture from the right rear cup holder hole, but there is no way I would get a hand down that far.
looks like I could reach it from the engine compartment if I took the sidewall off. Unfortunately it looks like that was installed before the starboard engine, so that will be a pain to get at all the screws.
Any advice would be appreciate
