On a 242 LSE or similar boat, where is the stock depth sensor located? Trying to figure out my true depth reading when out on shallow waters. Thanks y'all
I saw where mine was but I took a Measuring tape when I was out on the water to see actually how deep I was. Different boat though. In 3 ft of actual water I read on my Connext around 2ft. Which means if the Map shows 2' I am SOL, probably in a pinch. Mine is under the clean out hatch just outside of the keel.
