looking for a mechanic in NJ
Ramez
Limited
looking for a NJ mechanic in the NJ area that can repair a shaft seal leak in the hull. thanks
Yamaha 232 limited 2008
Glad to have you on board, sorry I can't be any help for a mechanic but keep in mind these are the same as a PWC so any good Yamaha ski shop should be able to help you,
do you see water coming through the seal/how much or do you just have water in your engine bay? we don't see shaft seals leak very often?
